Thread: Pool light only comes on if I tap the lens
    Jul 2012
    Florida
    Default Pool light only comes on if I tap the lens
    Hi, I am new to the sight, my pool light will come on by the switch, but not all the time. If it does not come on by the switch I have to go out and hit the lens once with my hand and it comes on and stays on. I put a new bulb in last year and the other day I soldered the all the connections in the junction box outside the pool, oh yea I have a in ground pool with a Hayward light system 12 volt.
    Is it possible that the bulb connector is bad, I tightened the outside screw, that did not work, I just find it strange that by hitting the lens makes it come on, nothing is loose, the fixture is tight and perfectly sealed.
    If anyone has any suggestions I would greatly appreciate it.
    Thanks,
    Joe from Florida
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  3. pool light
    By boscogabby in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2009, 12:00 PM
  4. Pool light color lens
    By Tomcat in forum Pool Equipment & Operations
    Last Post: 07-26-2006, 03:16 PM
  5. Pool light out
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 06-22-2006, 03:48 PM
