Results 1 to 3 of 3
Thread: Yikes!
    Jul 2012
    Michigan
    Default Yikes!
    I have an intex 15x 48 and underestimated the commitment! We purchased a salt water generator and I higher grade pump hoping that would make life easier. SADLY MISTAKEN. Just here reading and learning. Once I get a real test kit to figure out my green cloudy issue, I will return with a proper question. Until then wish me luck...
    Default Re: Yikes!
    Yeah, even with our help, the learning curve for pool operation is pretty steep!
    But, the good news is, once you 'get over the hump' it really is quite easy, IF you stay on top of things, with a good test kit, regular testing and plenty of chlorine added as often as needed!
    There's an Intex recipe and guide in this forum section that may help.
    Default Re: Yikes!
    Once you get past the hump as Ben called it, you'll find that you need no more than 5 minutes per day to maintain your pool.
  1. 1st year with a loop-loc cover...Yikes! Water is black
    By TomC in forum Dealing with Algae & Slime
    Last Post: 06-16-2012, 04:47 PM
  2. Yikes-De leaking into pool
    By Bergerman in forum Pool Equipment & Operations
    Last Post: 04-22-2008, 06:09 PM
  3. Yikes! Small pile of gravel in pool
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2006, 07:26 PM
  4. Pool/Spa Combo, Salt and Solar --- Yikes!
    By CalMan in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-02-2006, 11:15 AM
  5. Dimples in Liner Bottom (AG) Yikes!
    By bsbrega in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2006, 04:57 PM
