Results 1 to 3 of 3
Thread: How much DE?
    May 2012
    Phoenix, AZ
    Default How much DE?
    Hi,
    New poolowner here...
    My DE filter spec says to load 7.5 lbs of DE.
    When I do a backwash, does that mean I should load that amount, or something a bit less? The previous owner of the house said he loaded 5 lbs of DE after each backwash.
    Thanks,
    hikernut
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Default Re: How much DE?
    Hikernut,
    I have read the rule of thumb is to add 80% of your suggested amount which would be 6lbs if 7.5lbs is 100%. I think if you add 5lbs after backwash, which is just about 67% of 7.5, you will be fine. You may need to add more, but at least you won't add too much too clog things up.
    Make sure you know exactly how much DE you are adding. I only use a scooper specifically made for DE so I know the measurement is correct.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    May 2013
    long island
    My pool guy said 2 lbs after a backwash so you don't overload the grids and 4.5 when you install the filter which is the manufacturer recommended amount for a de-3620
    But 2lbs isn't 80% ..So I put 3 lbs just to be in between
    I hate getting different instructions from different people!!
    DE 3620 Hayward. 16x36 Inground rectangle (1995). 7.5 ft deep end 3.5 ft shallow. loop loc cover with mesh panels
