Results 1 to 10 of 21
Thread: Deep Blue Water MP3000 Mpluse - does it work?
    Feb 2012
    South Padre Island, Texas
    Default Deep Blue Water MP3000 Mpluse - does it work?
    Calcium climbs from 250 to 500 over 3 months, making it difficult to maintain a safe SI. TA @ 75 to 80 adj. to 55 to 60 using wheel, w/ CYA at 65. PH requires 8 to 12 oz acid every 3 days or so to bring down to 7.8 Pool is very warm 90+ now on So Padre Is. TX. I can't find any reviews on MP3000 but am wary. Does anyone have any experience?
    5000gal saltwater, gunite pool w/spillover spa, in So Padre Is, TX, EasyTouch4 w/IntelliChlor, UltraPure UV Ozone generator turned OFF, propane and solar htr.
    Jul 2012
    Mexico, Missouri
    Default Re: Deep Blue Water MP3000 Mpluse - does it work?
    Just out of curiosity, how new/old is the pool? Has it been recently replastered?
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Feb 2012
    Pool is 16 months old but they had to drain and acid wash about 6 months ago because the blue color faded significantly. I filled it w/ watersoftner water to keep the calcium down since our tap warer is close to 500.
    I had to grin at your post title: we've learned that when folks ask "does it work?" questions about chemicals, over 75% of the time, the answer is, "No!".
    So, I can tell you, no, it probably doesn't work, and have a very good chance of being right -- though I don't even know what it is.
    However, I'll check before I answer . . . so off to Google I go!
    In a word, No. Pure pseudoscience and snake oil. A quote from a description of how it works :
    "The MPULSE 3000 treats pool water by applying high frequency, low voltage impulses directly to the water to change the calcium bicarbonate to a carbonate form at the molecular level. In the carbonate state, the calcium can no longer adhere to pool surfaces."
    Considering that calcium bicarbonate does not exist exept as ionic species in slolution
    http://en.wikipedia.org/wiki/Calcium_bicarbonate
    and that calcium carbonate is the chemical that makes up scale deposits the above statement is pure bunk!
    http://www.chem1.com/CQ/aquacrack.html#DB
    (scroll down to Electrolytic Water Treatment)
    (scroll down to H20 Concepts)
    Now if you go to Deep Blue's current website they have change how it works by stating that the impusles convert the form of calcium carbonate that precipitates from calcite to aragonite (which is more soluble but form a much more difficult to remove scale deposit).
    http://books.google.com/books?id=nCF...termines%20if%
    (scroll down to calcite and aragonite)
    A much easier way to favor the precipitation of aragonite over calcite is to add magnesium to the water (which also favors the production of magnesium scale, which is much softer than calcium scale and much easier to remove, since it is what we commonly call chalk. Magnesium salts are sometimes added to salt pool to make the salt cells easier to clean for this reason but the jury is still out as to whether this works or not. In theory it should but things that should work in theory don't always when tried in the real world. Also, araonite tents to self convert to calcite in the presence of water at normal pool temperatures and aragonite scale is actually much harder than calcite scale even though it's solubility constant is higher, which means that it will not deposit as fast but once it does it is much harder to remove!)
    (FWIW, I was involved in an oceanographic physical chemistry research project at U of M in the early '70s in the precipitation of calcium carbonate from various seawater like solutions, artificial seawater, and Copenhagen seawater and one of the main things I was responsible for was determining whether the calcite or aragonite form would precipitate as we introduced various ions to the samples we would run so I have a bit of firsthand knowledge about this too.)
    Here is another article debunking the supposed way this system works:
    http://www.4water1.com/articles/aqa_ncdscience.html
    Don't waste your money!
    Spibill,
    I noticed in your sig that you have an ozone generator. They are basically worthless in an outdoor pool (but can be useful in an indoor pool with a persistent combined chlorine problem or in a bromine system). Ozone destroys chlorine and vice versa and in a pool is often likely to increase the amount of chlorine needed to maintain a desired free chlorine level. Ozone does NOT allow you to run a lower FC level (with a salt pool your FC should be at least 5% of your CYA and your CYA should be at the manufacturer's recommended MAXIMUM, which for the IntelliChlor is 100 ppm so you should keep your FC at 5 ppm or a bit higher). Under certain conditions (very high bather load, persistent CC problems) ozone MIGht allow you to set the cell output lower to achieve this FC level but the chances are it is actually requiring a higher setting of you cell then without ozone.
    The good news is that you have a UV ozone generator and they really don't do a whole lot (except waste whatever money you spent on it). CD ozone generators are the only ones that really work but they need a drying chamber and reaction chamber to be effective. Finally, ozone is not residual and there should be NO ozone in the water introduced into the pool, since ozone is extremely toxic. As an experiment, turn off the ozone and see if you need to change the setting on the SWCG to maintain the SAME FC level (which, as I said, should be 5% of your CYA which should be at 100 ppm.)
    Also, with a salt pool you will have better pH stability (and less chance of scale precipitating) if you lower the TA (UNADJUSTED) to about 70 ppm and do not let the pH climb above 7.8. Even with a CH of 500 or above this will keep your SI in range at temperatures up to 104 degress (for your spa). Adding borate to 50 ppm will also help lower the SI a bit so you have a bit more 'breathing room'. From playing with your numbers I don't really see you pool having a scaling problem, even with the high calcium (once the plaster is fully cured) if you keep the CYA at 100 ppm, FC at 5-6 ppm, TA 70 ppm, pH no higher than 7.8 (8.0 is fine if CH is below 500 ppm), CH below 600, and also consider adding 50 ppm borate which will further help lower the SI and also help stabilize the pH at around 7.7 for a longer period of time than without borate).
    Don't put too much stock in the wheel that comes in the K-2006 nor some of the info in the booklet.
    While much of it is good there is also some misinformation included. The info about the test interferences and the treatment tables are all that you really need. If you want to use adjusted TA because you are putting the CYA at 100 ppm the easy way is to just subtact about 33 ppm from the unadjusted TA. It will be close enough (or just put your unadjusted TA at 80 ppm and you should be fine, particularly if you add the borate.)
    Let's start with company and product info:
    Address (from Aquatics magazine)
    Deep Blue Water Technologies
    1345 E. Chandler Blvd., Suite 119
    Phoenix, AZ 85408
    Phone: (602) 441-9150 (877) 882-4695 Fax: (520) 887-0092
    www.4deepblue.com
    Brands: MPULSE 3000
    Address from BBB
    Phone: (877) 882-4695 Fax: (480) 497-4200
    3145 E. Chandler Blvd., #110-718
    Phoenix, AZ 85048
    http://www.4deepblue.com
    Another listed address:
    (480) 497-4200
    170 S William Dillard Dr Ste 104
    Gilbert, AZ 85233
    And, yet another listed address, from "Manta"
    Deep Blue Water Technologies, LLC
    3881 N Oracle Road
    Tucson, AZ 85705-3252 map
    Phone: (520) 887-2997
    OK. Looks like they've moved around quite a bit, but the BBB gives them an A+ rating, since there have been no complaints.
    http://www.bbb.org/central-northern-...az-1000001671/
    Description of 'how it works':
    Impulse technology uses 3000 to 5000 low voltage, high frequency electrical impulses per second to break down the calcium bicarbonate and magnesium bicarbonate crystals and change them into a powder form (carbonate). This powder form does not stick to the pool tiles or rock surfaces. No more calcification. The results will be a clearer, more enjoyable pool system with fewer maintenance costs. The MPULSE 3000« is easy to install in both new and existing swimming pools. And best yet, there is nothing to add and it needs no maintenance or servicing.
    http://www.ezpoolz.com/products/deep...00-mpulse.html
    OK.
    Bottom line: I do not know how it works, or if it works. My STRONG suspicion is that it has ZERO effect on the calcium in your pool.
    In fact, if you can come up with some way to TEST whether it works or not (that we can agree measures fairly), I'll bet $100 to your $1, that it does not work.
    The copy reads just like the magnets they used to sell to do similar things, and as far as I know, there has never been ANY evidence that they did anything useful, EITHER. At least part of the description above, is chemistry bunkum:
    That quote is not just wrong, it's stupid. Calcium bicarbonate is extremely soluble, but even more importantly, does not exist in solid form, much less as crystals! Magnesium carbonate -- to get magnesium bicarbonate, you have to dissolve, and then acidify magnesium carbonate -- is just chalk, and not very prone to forming "crystals". And to say that "carbonate" = "powder form" is simply nonsense, sort of like saying that "water" = "heavy" or "iron" = "yellow".
    But, I've invited Chem_Geek and Waterbear to weigh in with their reactions.
    Links:
    http://en.wikipedia.org/wiki/Magnesium_carbonate
    Feb 2012
    Thanks for all your efforts. You confirmed my suspicions.
