Re: Stubborn green water in an in-ground pool.
Interesting, so for the lay person, metal testing is unreliable to the point of being useless? So do we just assume because my pool water had been on the acid side and I have mostly copper pipes, I probably have some copper?
To my knowledge, I haven't used any pool products that contain copper. I checked our chlorine pucks and they do not have copper.
I also looks like I left off the first part of my post with my test results. I tend to type in a document and then cut and past so I don't lose stuff if a posting goes wrong. So here it is again;
We recived the Taylor 2006A test kit today. Here's the results;
FC- 1.2 ppm
CC- 0.2
pH- 7.0
TA- 120 ppm
CH- 875 ppm
CYA- 90 ppm
17x40 free-form 35K gal IG pool; trichlor feeder; System:3, S8D110 DE filter; Max-E-Glas II, 1 HP pump; 4.5 hrs; OTO kit - K2006 ordered; utility water; none; PF:3.4
