Test Results...I think!
I finally got a test kit. Those little buggers aren't cheap. We have a SWG but I am not using it until I can get things figured out. Is that okay?
My chlorine didn't even register on the drop kit.
I just did a shock yesterday. (the strips said I was in range...But I know that isn't overly accurate)
PH is 8.2
Alk I got to 15 drops and the color never changed so I stopped...
CYA appears to be zero
I know these aren't really all the numbers, but I feel I may need to get the PH and Chlorine figured out before I go any further. I have purchased some crazy saltwater pool start up chemical at Wal-mart, only because it was the only one with CYA in it. I also have bleach, borax and a PH riser chemical (not Baking Soda, just because Wal-Mart is out...CRAZY)
Any input would be great. If you need more information please let me know. Thanks!!!
