Results 1 to 10 of 24
Thread: Time to Take My Pool Back from Leslie's
    Jul 2012
    Alabama
    Default Re: Time to Take My Pool Back from Leslie's
    I filled out the chart. Not really asking anything yet. I assumed that the right place to start here was with accurate test results from the recommended testing products, so I was going to wait on that to come in from Amazon before I started trying to do anything. This was mainly intended as just a "get established" post.
    I threw four pounds of 73% NaClO in and scrubbed yesterday evening. Right now, the pool looks blue and cloudy. It's got a LOT of dead algae in it. This seems to be a problem in my clean up efforts; I'm not sure if my filter is operating efficiently. I started vacuuming it before I scrubbed it, and saw the algae blowing through the outlet valves, right back into the pool. I went to Leslie's and got some floc, thinking that would help me get the algae out. The instruction label didn't say that I should vacuum it to waste, which I thought I should. Googling the product actually lead me here. That's when i started reading some things on this site and these forums that made a lot of sense.
    Anyway, if you think you can help me from here instead of waiting on the test kit to come in, I can provide you with some basic water info that may not be as accurate as what the new test will show. I guess the sooner the better. My wife wants to have some of her girlfriends over to swim on Aug 11. Seeing as how I enjoy looking at women in swimwear, I'm eager to oblige.
    Thanks for your response and offer to assist.
    Sorry - in my previous post, I meant calcium hypochlorite (Power Powder Pro), not sodium hypochlorite.
    28x34 L 20K gal vinyl IG pool; skimmer tabs; sand filter; K2006; utility water; PF:6; net-dev
    Having algae blow back into the pool is a problem. If the algae is DEAD, this indicates you have a filter problem. If the algae is ALIVE, you'd be better off vacuuming to waste.
    Looked at your Pool Chart data.
    If you want a clear pool on Aug 4, you probably should:
    1. Vacuum the algae to waste;
    2. Purchase and use a SINGLE dose of a locally available pool clarifier;
    3. Open and check your filter for adequate sand, and for lumps and channels.
    4. Report COMPLETE test results (do you have a K2006, or have one ordered?)
    Jul 2012
    Alabama
    It's not quite that desperate - I'm shooting for Aug 11, not Aug 4. With that in mind, are your steps still the best course of action? If so...
    1. Should I go ahead and use the Leslie's Super Floc that I bought before I vacuum to waste?
    2. I've dumped a lot of clarifier into the pool in the past week or so - a full quart of Leslie's Clear and Perfect (one oz is supposed to treat 4000 gallons, use more for very cloudy water), and a few weeks ago a bunch of Leslie's PoolPerfect+PhosFree. Continue with more?
    3. See my picture links below. It looks to me like I'll have to cut two pieces of PVC to open the filter; am I wrong?
    4. I just ordered the K2006 from Amazon last night, as mentioned above. I haven't gotten shipping confirmation yet; I'd guess it won't be here until next week.
    Here's how my pool looks right now.
    Here's the hardware I'm working with, relevant to my question number 2 above. BTW, I've never used the New Water Cycler you see in this photo. I moved into this home with all this already installed, and when I researched the New Water, it didn't really seem advantageous.
    Here's info on my filter and pump, just because I didn't have them handy when I filled out the chart.
    Thanks, Ben.
    I'll look at the other, later, but a BIG WARNING right now:
    If you've already used a "bunch" of clarifier, do NOT use any more, and do NOT use any floc.
    Regarding the filter: if it was DEAD algae that was blowing through the filter, yes, you probably should open it. If you want to be sure, get some DE filter powder, put a couple of cups in the skimmer, and then see if that blows through. If so, your filter definitely needs service.
    (PS: the "pump" photo is actually the pump MOTOR; you need a picture of the pump wet end, too.)
    Jul 2012
    Alabama
    Regarding the clarifier - understood.
    Regarding the DE filter powder - I'll try to do that tomorrow after work.
    Regarding the pump (motor) - sorry, if it's important, I'll try to find other identifying marks or tags.
    Thanks again. I really want to get out of the "pool store cycle."
    RE: pump motor. It's an up rated 1 hp round flange (so it's a 3/4 HP pump in reality) A.O Smith replacement motor (not the original pump motor). The pump itself is most likely a Hayward or a Jacuzzi Magnum series since they all use round flange motors. My guess would be one of the Hayward pumps given the Hayward sand filter.
    BigDave's Avatar
    Lightbulb Re: Time to Take My Pool Back from Leslie's
    Quote Originally Posted by pentachris View Post
    ...It looks to me like I'll have to cut two pieces of PVC to open the filter; am I wrong...
    Yep, you'll have to cut the pipes to open the filter. If you install Unions when you put it back together, you'll be able to open it without cutting in the future.
    Jul 2012
    Alabama
    I went to Leslie's on Saturday to replace my vac hose (warranty claim - I still had the box stating "3 year warranty" that was dated 11/09 - sweet!).
    I forgot to get DE powder to check the filter while I was there.
    I vacuumed the dead algae to waste, probably dropping my water level by 12 inches or so. I refilled and put in 2 lbs of Power Powder Pro to try to keep it sanitized. That chlorine is now gone.
    My K2006 test kit was delivered today. I've got pretty much 0 FC & CC; I added probably 15 little scoops of that powder and it barely gave the water a faint tinge of color.
    My PH is 7.4.
    Alakanity is 110.
    CH is ~700. Yes, really. I followed the instructions in the Taylor testing instructional video about avoiding interference in a CH test. A few weeks ago, Leslie's told me they couldn't accurately read my CH and sent me home with a bottle of "Metal Free." After doing some reading around here, I wonder if it's because of the insane amount of Power Powder Pro (calcium hypochlorite) I've put in my pool this year (not exactly sure how much, but it's been over 100 lbs). Trichlor skimmer tabs don't seem to be cutting it, either, so I guess it's time to switch to bleach.
    CYA was less than 30. Of course, it's hard to tell when it's outside of the range of your testing equipment, but if I had to guess based on level of opacity, I'd guess ~10. Maybe the trichlor tabs would be sufficient if my CYA were better??
    Currently, the water looks clear, with a few spots of dead algae (pale sand-colored silt) on the bottom. I've got an idea of where I need to go from here, but I'll leave it to the experts to guide me. I will go ahead and ask a question, though - does it make a difference whether I use liquid or granulated CYA? Liquid has been MUCH more user-friendly in the past for me.
    My wife is having folks over this Saturday (5 days from now), so it's imperative that I keep it swimmable until then, or return it to swimmability by then.
    Thanks for the help and advice.
    Don't do that; if it doesn't turn pink with 2 scoops, it's not going to turn pink. If you want to confirm a reading, use OTO drops, which are not super accurate but are extremely reliable.
    Actually, with a sand filter, if you'll remove any chemicals or tabs from your skimmer, you can LOWER your CH by adding the cal hypo via the skimmer. You must be 100% certain that there are no OTHER chemicals the cal hypo will contact, before you do this! And do it cautiously -- small doses -- at first, to make sure the calcium doesn't blow through your filter.
    If you have access to a Sams Club, go get a box of their PoolBrand 1# dichlor bags. Otherwise, order dichlor from Amazon:Kem-Tek Dichlor 22 lbs. The dichlor can be dumped straight into your pool, and will raise both CYA and chlorine. Dichlor is cheaper than liquid CYA . . . even if you count ONLY the CYA content, and not the chlorine.
    Use the cal hypo -- test the small doses and then work up to 5 ppm overnight skimmer doses as quickly as you can. Ironically dosing this way will actually INCREASE your pool's clarity, though you'll have to backwash more often.
    Jul 2012
    Alabama
    Other chemicals such as what? How would I tell?
