Thread: algae?
    May 2012
    ohio
    Default algae?
    I started using the forum this spring, and have had great success dealing with some situations that have come up! You guys are great. I now have something that I can't seem to get through. Last week we started having what I think is algae popping up on the floor of our pool. it is spotty all over.
    Not really sure why?
    Have a Taylor test kit, here are the last readings: Ph 7.8, FC 9 (high because I shocked it), CC .5, CYA 50ish. We have been sweeping every couple of days and I have shocked, but it just keeps showing up. I am following the directions I had in the spring to take care of the algae. We do fill with well water, and had to do so quite a bit this summer. I also have not had much luck getting my alkalinity lowered, last I checked it was 190.
    Default Re: algae?
    What do the areas on the floor look like? Does it feel slimy? Could it just be dirt? In my pool, no matter how clean I think I get it when I vacuum (and I go VERY SLOWLY), once the water quiets down, I always have a little dirt that has been in suspension in the water while I vac and then re-settles on the floor.
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Wanted: Mustard algae or suspected mustard algae
    By gonefishin in forum Dealing with Algae & Slime
    Last Post: 08-30-2007, 09:40 PM
  4. Green algae? Mustard algae?
    By AE340B in forum Dealing with Algae & Slime
    Last Post: 07-15-2007, 09:32 PM
