Results 1 to 10 of 11
Thread: Skimmer Sock or Panty Hose in Pump Basket?
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Question Skimmer Sock or Panty Hose in Pump Basket?
    My DE filter grids need to be replaced; however, I have decided to wait until next season to replace them. I don't want to install new grids then have them damaged over the winter. The current grids do not filter very well. DE does not stay coated on the grids. I find myself vacuuming up DE that is blown out the returns along with other small debris that is not trapped by the faulty grids.
    I started using a skimmer sock to trap as much debris as I can before it reaches the filter. When I vacuum it is very frustrating that about 50% of what I vacuum comes out the returns. As a short term experiment, I was thinking of trying a skimmer sock or panty hose on the pump basket to trap debris that is vacuumed.
    Has anyone tried this? Is this a bad idea?
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    Lehigh Valley, PA
    Default Re: Skimmer Sock or Panty Hose in Pump Basket?
    I sometimes vacuum with a skimmer sock in the SKIMMER basket and, as WM says, you have to watch your pressure. I can get about 1/2 of the pool done before I have to change the sock. I have not put one over the PUMP pot/basket because I'm too afraid of it getting sucked into the impeller (via Murphy's Law).
    do not use a swimmer sock in the pump basket. The chances are excellent that it WILL get sucked into the pump and could cause the impeller to seize and damage your pump motor.
    Jun 2012
    Pennsylvania
    @ Waterbear: Thanks for the reply. That is exactly what I was afraid of happening.
    Do you have any other suggestions how I can trap vacuumed debris before it gets to the filter?
    @ Anna:I can't follow your approach with the skimmer sock since I need to remove the skimmer basket to insert the hose.
    Any ideas are appreciated since vacuuming multiple times per week has gotten old very quickly.
    Lehigh Valley, PA
    Okay, was worth a try. I have an adapter that goes over the skimmer basket and that the vacuum hose connects to. That way, large debris stays in the skimmer basket rather than going straight to the filter. This may not be available for inground pools.
