Re: Chlorine Bleach & pH
When I look in the instruction manual in the Taylor kit, it says that liquid chlorine has a pH of 11-13 and has a high acid demand. I am confused - I thought that adding 10% liquid chlorine would raise the pH & TA. I haven't had a problem like this before using the liquid chlorine. I read through the sticky - so I should aerate and add muriatic acid to lower TA? I will test fill water in a bit.
18x38 roman 30K gal IG vinyl pool; 10% bleach; Hayward SP0714 sand filter; Pentair WhisperFlow pump; 24 hrs; Jandy Lite 2 pool heater.; K2006A; utility water ; summer: automatic; winter: automatic; ; PF:4
