Well lets see, two opposing views, but I might be more inclined to side with Rangeball on this one...
waterbear wrote......
Disadvantages of MPS shock?:
1 it is expen$ive ---------becoming a nonissue with the rising cost of bleach
MPS is more expensive than Cal Hypo for equivalent usage amounts
2 it is only an oxidizer and not a sanitizer----- already a nonissue because I am talking about shocking not sanitizing, naturally one would use chlorine for day to day sanitizing
Not really, shocking is part of the sanitizing process. MPS ideally should burn off organics before they become chloramines, in real life you shock after you have CC....see 4 for when they have become chloramines.
3 it will show up as CC on a DPD or FAS-DPD test unless you use a special test kit (additional expen$e) --- this is a valid issue, but once I convert over to the other test procedure, costs should be about the same?
you need an ADDITIONAL test plus what you are already using. Talor lists theirs on their website at $18.95 plus shipping
4 it can convert chloramines to nitrates which are algae food---- this is somehting that I do not know much about, nor have heard any convincing discussion one way or the other. If there is good evidence that PMPS increases the likelihood of algae formation, I would like the opportunity to read about it.
Is Ben (PoolDoc) a good enough source? Check out http://www.poolsolutions.com/tips/tip38.html
5 it is expen$ive------ get over it already.....
6 see number 4!---------ditto
7 it seems to work better with bromine than chlorine (but chlorine is STILL a better shock for bromine)--- probably but again a nonissue here....who uses bromine in their pool?
Bromine is often used for indoor pools where it can have some advantages.
8, 9, 10, ------did that add anything to your argument?
Hal
