Thread: Bleach time frame ?
    slowtan is offline ** No working email address ** slowtan 0
    Houston, TX, USA.
    Default Bleach time frame ?
    What kills the strength of bleach?
    Time
    Heat
    sunlight
    I keep my bleach in the garage .. no sunlight but plenty of heat. I buy those 3-pack of 1.42G from Sams but by the time I am on the 3rd bottle the smell is not that strong.
    Just curious what weakens bleach.
    Default Re: Bleach time frame ?
    You've pretty much got it!
    Mesa, AZ
    I would put them in the order
    1) Sunlight
    2) Heat
    3) Time
    I figure Sunlight is never OK, but Heat is OK if time is short enough and Time is OK if heat is low enough. Heat and Time together = weak.
    Smell may not be a reliable indicator of the strength of the bleach. I have had some stuff that had no smell that really rocked the FC.
  1. Trying bleach and borax for the first time
    By klyeany in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2012, 11:09 AM
  2. First time adding chemicals to 18x48 intex ultra frame pool..HELP!
    By babyblueiz77 in forum Intex-type Pool Setup & Operations
    Last Post: 07-10-2012, 10:15 PM
  3. looking for Help with intex ultra frame pool 12 x 36 (frist time pool owner)
    By jon56048 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-14-2012, 12:00 AM
  4. Best time to add bleach
    By douge55 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-29-2011, 06:34 PM
  5. Pool Still green after 20 gals of bleach...1st time post.
    By Steve V in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2011, 11:03 PM
