Results 1 to 8 of 8
Thread: Salt drop test
    Default Salt drop test
    Could someone direct me to a website that sells a testing kit for salt levels in a pool? The info would be greatly appreciated. We are going to buy an SWG. We have been filling with softened water for 2 years and adding lots of bleach because of our heavy swim load. We would just like to see where our salt levels are already. Thanks, Dorie
    Saint Cloud, FL
    Default Re: Salt drop test
    You can order the Taylor salt test kit (#K1766) from your local pool store. Do not be sidetracked into buying a meter, which will cost 5 - 6 times as much, and not give the accuracy.
    Or you can order Ben's PS234 test kit which has the salt test kit included.
    Pat
    Quote Originally Posted by PatL34
    Pat
    A properly calibarated meter will give you the accuracy. If you have your own meter and standard solutions for calibration and keep it calibarated it is probably more accurate than a drop based test. It will cost a LOT more money however! Goldline makes a good portable, waterproof one and the MyronL meters are an industry standard.
    Also, I have double checked the aquachek salt test strips several times against a meter and they are pretty much in the ballpark and fairly easy to read (but the test does take a while to complete...not exactly dip and read!) they use the same chromate/siver nitrate chemistry as the drop kit but the drop kit does give better resolution (accuracy) at higher salt levels (above about 2500ppm or so)
    Mesa, AZ
    I have strips that I got from the builder when starting up my pool. Drop kit I found at the local Leslies for about $20, and a waterproof meter with 3000 ppm calibration solution I got from E-bay for about $50. The are all within about 100 ppm of each other. The Meter is by far the easiest, but I haven't had it long enough to know if the calibration holds well. The drops are a bit freaky to use (solids preciptate out etc.), but the color change is VERY clear. Resolution on my kit is 200 PPM. Strips are still accurate after 2 years, but are annoyingly slow to use. They all work well enough to figure out how much salt to add
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    cwstnsko, could you tell me what model meter you bought? I have a SWG on the way and if a meter can be had for $50 that's a no brainer, IMO. How does the quality stack up against other meters?
    Thanks.
