Results 1 to 8 of 8
Thread: Salt drop test
Threaded View
  1. #8
    Default Re: Salt drop test
    Quote Originally Posted by cwstnsko
    The one I bought has both Eutech Instruments and Oakton Instruments on the Instructions. The model seems to be SaltTestr. I'm not sure if it's a good or bad one, I just liked the price. It came with 2 envelopes of the 3000 PPM calibration solution. I'm not sure how long it will go without needing to be calibrated, or how long the electrodes last. It does have replaceable electrodes, but I'm not sure if I could find a source. I haven't looked yet.
    The Goldline salt meter (which I use at work) is basically a rebranded Oakton. They hold the calibration pretty well, and the electrode is self cleaning and temperature compensating. (still a good idea to give it a quick rinse in distilled water after the test) Goldline controls sells theirs for around $130-$140. If I am not mistaken Eutech acutally manufactures the meters for both Oakton and Goldline in Singapore and Malaysia. IMHO, it is a better meter than the LaMotte pocket testers, which are the only other ones in that price range. The MyronL meters are pretty much industry standards for the pool stores but they cost a bit more. They have a model that is switchable between TDS and Salt and have several single funtion meters for salt but they are not dip and read. I use a MyronL for TDS testing (not that I actually test for TDS very often!)
    As a side note on your finding the drops, meter, and test strips all giving pretty accurate results, I bet that the display on your SWG does not agree with them! For some reason the readouts on most of the SWGs that I have tested the water for is usually off by anywhere from 100 to 400 ppm compared to the other forms of testing. I don't know why but I suspect it has to do with the temperature in the cell which usually runs higher than the temp the water is tested at with a stand alone meter, a strip, or a drop test.
  1. HTH 6-Way Drop Test vs the Older HTH 5-Way Drop Test
    By CarlD in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2012, 07:35 AM
  2. Borate drop test vs strip..
    By rcy100 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2011, 09:43 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Drop test kit question
    By jd.pool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2006, 10:28 AM
  5. My first drop test kit results
    By Rangeball in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 10:31 AM
