Results 1 to 5 of 5
Thread: Spongy Ground
    Jul 2012
    Ontario, Canada
    Default Spongy Ground
    Hey -
    I started to level my pool, and have this one spot that is "spongy". I step on it, it sinks, then I move and it comes back up. I thought there was a monter in there so I put a 12" nail and nothing came out If I can shove a nail in the ground with my hand that can't be good.
    The spot is 1x1ft.
    Should I dig it up? It would be near one of the corners in my 15x30 oval pool.
    Thanks,
    Brad
    Lehigh Valley, PA
    Default Re: Spongy Ground
    I would, just to see what's in there. And how big/deep it is. Could be an abandoned rodent den, could be pirate's treasure, could be where someone had buried a pet. Probably ought to be filled in before you locate a pool near it.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
    BigDave's Avatar
    Jul 2010
    New Jersey
    Remember to compact the soil you use to fill the hole or you might as well build the pool on the spongy spot.
    Jul 2012
    Ontario, Canada
    Well I dug it up, and turns out there used to be an old tree stump a couple of feet down. It was the spongy culprit. I dug it out, put a few shovel fulls of dirt in at a time compacted, put a few more, compacted, and so on until it was full.
    Lehigh Valley, PA
    Glad it wasn't a pet grave.
