Thread: Spongy Ground
    Jul 2012
    Ontario, Canada
    Default Spongy Ground
    Hey -
    I started to level my pool, and have this one spot that is "spongy". I step on it, it sinks, then I move and it comes back up. I thought there was a monter in there so I put a 12" nail and nothing came out If I can shove a nail in the ground with my hand that can't be good.
    The spot is 1x1ft.
    Should I dig it up? It would be near one of the corners in my 15x30 oval pool.
    Thanks,
    Brad
    Lehigh Valley, PA
    Default Re: Spongy Ground
    I would, just to see what's in there. And how big/deep it is. Could be an abandoned rodent den, could be pirate's treasure, could be where someone had buried a pet. Probably ought to be filled in before you locate a pool near it.
    BigDave's Avatar
    Remember to compact the soil you use to fill the hole or you might as well build the pool on the spongy spot.
    Jul 2012
    Ontario, Canada
    Well I dug it up, and turns out there used to be an old tree stump a couple of feet down. It was the spongy culprit. I dug it out, put a few shovel fulls of dirt in at a time compacted, put a few more, compacted, and so on until it was full.
    Lehigh Valley, PA
    Glad it wasn't a pet grave.
  1. Spongy ground
    By Ronda in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2013, 09:16 PM
  2. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  3. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  4. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
