Results 1 to 10 of 23
Thread: Cya testing
    Lehigh Valley, PA
    Default Re: Cya testing
    With Leslie's, it depends on the individual store. The one here carries R-0014, for instance, but not R-0004. Their Website does say to check for local availability. Good for you for mentioning PF to the customer. I've done that once or twice.
    Jun 2012
    Michigan
    Even thou I just added a lb of CYA on Tuesday, I couldn't wait to try the test. I got a reading of 40. I am out of reagent 0871 as stated above and did my final FC/CC test until the replacements get here. My results below: 10ml tests
    FC 15
    CC 0.5/1 Hard to tell for sure last drops in bottle and they just flew out.
    pH 7.4
    CYA 40
    Going to calculate the amt. of bleach to put in to reach shock level of 30 with a CYA reading of 30-50. I have a group coming over to swim on Sunday and would like this last little bit of algae killed and vacuumed up by then.
    On Ben's best guess pool chart there are 2 shock levels...what is the difference? One is 'SHOCK' and the other is +SHOCK+
    15' x 48" round 4.4K gal Intex AG pool; Unicel Type C-5315 cartridge filter; Intex 633T pump; (24/7) Taylor 2006 kit; utility water; summer: ; winter: ; iPhone; PF:27
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    Quote Originally Posted by RedwingT View Post
    The SHOCK is for stardard shocking of the pool and the +SHOCK+ is for Mustard Algae shock levels.
    Jun 2012
    Michigan
    Thanks jwhouse, if I had to guess that is what I would have thought. Now it's confirmed.
    BigDave's Avatar
    I like your new avatar!
    Jun 2012
    Michigan
    Thanks Dave! Sure beats the pic of the ground before installation!
    Wanted to give a shout out to DiscountPoolMart on Amazon Marketplace. I ordered the 3 reagents on Wednesday August 8 and received them today Saturday! Estimated delivery was August 15! So I actually only went 1 day without being able to test! Fast A+ service!
    Sep 2012
    South Eastern Utah, USA
    I bought my kit at amazon, but also visited the taylor technology site. they also have what you'll need. MY CYA level has dropped to 30. I have isocyanuric acid granules that I used before I converted from SWCG to BBB. Is it OK to still use that?
    Yvonne
    16x32 rectangle 14.6K* gal Intex AG vinyl pool; Household Bleach; Sta-Rite System 2 cartridge filter; Waterford Systems 1 speed pump; 8 hrs; Taylor K2006, HTH 6 way test strip; well; summer: none; winter: intex provided cover; android phone; PF:8.2
