Thread: bluish goo in cartridge after using borax
    Default bluish goo in cartridge after using borax
    Earlier this season I helped my neighbor get his water issues straightened out. He has a 24K Gal IG vinyl pool with a cartridge filter treated with CL.
    His pH was so low from years of low pH I presume-- To get his pH into the 7.4 range it took about 40 lbs of 20 Mule borax. His pH still in the 7.4 range and TA around 100 so that is all good. But now his filter cartridges are getting gummed up with a bluish substance and we are wondering if its coming from the borax?
    Any help would be appreciated, because I want to get everything right for him.
    Default Re: bluish goo in cartridge after using borax
    So I guess I stumped everyone and no one has seen blue debris stuck in the cartridge filter after using borax?
    So here is a theory I have-- Is it possible that the pH was so low for so long that the copper eaten away from the destroyed heater now precipitating since the pH is less acidic and the copper precip is being caught by the filter?
    It is possible, and I would think probable, for your theory about the low pH destroying the heater and releasing copper into the water. There was another thread on the forum during this summer regarding large amounts of blue "goo" being washed out of the filter--I'l have to do some searching and see if I can find it.
    Didn't stump me.
    It's not the borax.
    Are the endcaps on the filter by any chance blue? I have seen the rubber endcaps turned into 'goo' by very low pH more than once and you descrbe a VERY low pH situation that was present for probably a long time.
    Check the endcaps (both of them) and see if they are soft and/or sticky. I bet they are! I also bet there is blue 'goo' all inside the filter chamber.
    The only other thing I know of that will cause blue goo to collect in a filter are some clarifiers. Have clarifiers been added to the pool? (although my money is on the endcap being damaged by very low pH.
    Waterbear, so you don't think its possible that the blue (that has a definite copper green cast to it) was caused by the copper that got put into the water when the heater copper on the heater was destroyed by low pH and is now precipitating out at higher pH?
    I will definitely get a good look at the filter end caps. I presume when you say filter end caps, you mean the rubber/plastic that is mounted at each end of the pleated cartridges correct?
    If it is gummy (you said the carts are gummed up by it) then it is probably from the endcaps at either end of the cart. The color tends to turn a greenish blue color and is gummy or sticky. Copper carbonate is not gooey and will tend to deposit as a blue green stain on the cart and in the pool itself. In either case, it is not from the borax but is a result of low pH conditions in the water. IF the total alkalinity was very high (doubtful if the pH was so low unless you also used pH increaser, sodium carbonate, or added sodium bicarbonate to raise the TA) then the low pH would have depleated the bicarbonate in the water so the precipitation of copper carbonate is doubtful even if there is a lot of dissolved copper in the water. If there is high TA and high pH then it is possible for copper carbonate to precipitate but with an extended low pH situation I don't think that is what occurred. There very well might be copper in the water from the heat exchanger also.
  1. cleaning cartridge
    By sun and water in forum Pool Equipment & Operations
    Last Post: 07-19-2012, 04:09 PM
  2. Bluish/greenish particles
    By MRL325i in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2012, 06:17 PM
  3. cartridge filter with swg
    By cofa in forum Pool Equipment & Operations
    Last Post: 10-05-2008, 01:24 AM
  4. DE vs Cartridge Filters
    By jmce1587 in forum Pool Equipment & Operations
    Last Post: 08-06-2006, 01:11 PM
  5. Test results - bluish cloudy pool
    By 4KidsSwim in forum DPD-FAS based testing
    Last Post: 08-05-2006, 12:36 AM
