Thread: Unsalted pool has 3680 ppm salt level?
    Aug 2012
    Florida
    Default Unsalted pool has 3680 ppm salt level?
    I just obtained an Aquatron Cobia XL Pool Robot. In anticipation of using this new gadget, I went and bought a truck-load of pool salt and some AquaChek White Salt Titrator strips. I've had the pool for 14 years, never had salt before, but when I used on eof the strips to see how much I would need to add, it tells me I already have 3680 ppm salt. How can this be?
    Default Re: Unsalted pool has 3680 ppm salt level?
    The salt test strips are a test for chloride ions in the water. All forms of chlorine produce chloride ions when the chlorine is consumed. That is the source of your salt in the water.
    Aug 2012
    Florida
    OK, since the Cobia SWCG only calls for 3000, I don't need to add any salt?
    should be fine. If not the hybrid pool robot/SWCG you have should tell you.
  1. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  2. Salt level?
    By court475 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2009, 01:11 AM
  3. Ideal Salt Level Pool Pilot
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2008, 11:46 PM
  4. Low chlorine level in a salt water pool...
    By Strawfoot in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 02-07-2007, 10:22 PM
  5. my salt level
    By Bowlin in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2006, 02:44 PM
