Re: At My Wits End
aylad
With a CYA of 40, your shock level is 15 ppm--have you consistently kept it above 15 for the time you've specified, or did you let the chlorine levels yo-yo up and down? If the chlorine level isn't consistenly kept above that 15 ppm, then you're spinning your wheels--and wasting your time. If it's been consistently above the 15 ppm, and is still green, then I would either double-check your CYA levels, or check with your water company to make sure there are no metals in the water.
I'm betting that I'm spinning my wheels. I need help with this because it's just not registering for some reason. How long should my Chlorine stay above 15ppm? Until it's clear? I just keep dumping in bleach? Last night my FC measured at 10ppm. I poured in a gallon of bleach at 8pm. As of 5am this morning my Chlorine is up to 19ppm. How can I hold it there? Should I put in more bleach now? Should I test again at noon and if it's below 15 I just dump in some more bleach?
I'm sorry if I sound ignorant.. but I really want to get this right. I am wasting so much money and the pool is essentially useless until we clear it up.
By the way.. the water turned much darker green yesterday.
21' round 10K gal AG pool; chlorine tabs; sand filter; pump; 12hrs; full Taylor Kit; utility water; android phone; PF:12
