Results 1 to 9 of 9
Thread: hurricane & pools
    Default Re: hurricane & pools
    Plaster pool..... with Diamond Brite....
    I have a swc but what would you use to shock it without using the swc... beach? shock? and how much??
    10,500 gal pool/spa
    Mike
    Saint Cloud, FL
    Distribute the bleach around the pool and spa, adding about 2 gallons based on Mike Smith's bleach calculator to bring it up to about 15 ppm.
    Pat
    Boca Raton, FL
    ....not to sound stupid, but shock with bleach (straight regular old bleach?) and bring what?? up to 15ppm. What is it that I'm bringing up to 15ppm (chlorine?)
    Shari in South florida
    xoroniox is offline Registered+ Thread Analyst xoroniox 0
    South Florida
    Quote Originally Posted by Looony2nz
    shock = bleach = chlorine = liquid shock they are all the same thing, sodium hypochlorite. only diffrence is concentration levels, as long as the "straight regular old bleach" has no scents or additives its fine to use. you are bringing up your chlorine levels in the pool to 15 Parts Per Million. hope that clears some stuff up for you.
    -Arron
