Hi,
We have a 20x40 IG liner with a Hayward heater. Everything was installed last Sept. (2005) and closed a few weeks later. We opened the pool about a month ago and cleaned everything up and balance the water. I have Ben's test kit. Everything was great and then we turned on the heater. When the heater is on, the water comes out of the returns cloudy. It seems to disapate and the rest of the pool is not turning cloudy. It will stop coming out cloudy for a little while and then all of a sudden it's cloudy again. This only happens when the heater is on. At first I thought maybe something was settled in the line so we let it run for a while. It turned to clear and then about 30 minutes later went back to cloudy. Here's the info on the pool ...
20x40 inground liner approx. 33,000 gallons. Aqua logic system with salt water generator. Hayward DE filter. Hayward H400 heater - propane.
FC: 4
CC:0
TC:4
PH:7.5
Alk:90
Cal: 160
Salt: 3200
Water temp. before heater turned on: 68 to 70.
Set heater to 78
Any thoughts on why I'm getting this cloudy water when the heater runs?
Thanks!
Tracy
