Re: Pool is green...Need Help
PoolDoc
Was this Walmart bleach? Bleach with no listed % is probably VERY low. You might want to check the label again -- I'm not sure if genuine bleach can be sold without a %; Walmart Great Value bleach is listed at 6%
The CYA test is NOT a drop count!
Watch the Taylor videos from this page:
http://www.poolforum.com/pf2/showthread.php?17157
Then what am I multiplying by 3? The video says to simply read the water level on the tube. So...if the water level ends up at the 100 line when the dot disappears, do I still multiply by 3 and have 300 as my result?
Also...you didn't clarify on the 7ml versus 14ml question above. The video and my instructions say to go to 7ml line with sample and add R0013 till you reach 14ml line. You're saying to use 14ml sample and 14ml of R0013. I just want to make sure. And to do that...I'll need to use another container to dump the 14ml of sample into and then the subsequent 14ml of R0013 into to mix.
13x30 rectangle 13K gal IG concrete pool; skimmer tabs and liquid bleach; Sta-Rite cartridge filter; Hayward 2Hp pump; 5.5hrs; Taylor K-2006; utility water; summer: none; winter: none; ; PF:9
