Results 1 to 9 of 9
Thread: Shopping list for BBB
    Aug 2012
    canada
    Default Re: Shopping list for BBB
    Ok Shopping list completed. Unfortunately i could not find non-clorox bleach at costco. So i got 6 jugs of clorox 6% bleach, 2 big bags of baking soda arm and hammer from costco, 5 boxes of borax, a hth 6 way test kit, some cya stabilizer from pool store, kem tek 22.5 lbs dichlor (2) pails from amazon, and the k 2006c is on order. I am new to pool maintenance and balancing since i have only had the pool since start of August 2012. I use the 6 way test kit and the dip strips to check for free cl and cya since the hth 6way does not check for that 2 times a day morning and night.
    My questions:
    1. Is there a guideline for daily/weekly routine for keeping my pool balanced?
    2. How do i know how much of each BBB to add to increase ppm for each category?
    3. How long do i need to wait for the chemicals BBB to take affect before i test again?
    4. Is the Kem-tek dichlor to be used instead of my trichlor puck that i put in skimmer?
    Thanks for any help guys. I would be lost without this forum.
    15x30 oval 10.6K gal AG vinyl pool; swcg; hayward s-180t sand filter; hayward ultra - pro lx pump; 10 - 14 hrs; strips right now but i want a k 2006; utility water; summer: solar; winter: none; android phone; PF:11
    Aug 2012
    canada
    sorry 6 way hth dropper and also those crumby test strips too. i use the dip strip to tell my cya cause i ran out of the hth cya regent.
    In spite of the name, BBB is an approach, and not 3 chemicals.
    A core element of the approach is accurate testing. In particular, it requires accurately testing CYA (stabilizer) levels, and adjusting chlorine levels accordingly. The "Best Guess" page explains how and why.
    Another element is using chlorine chemical side effects beneficially. For example, when your pH is too high, and your CYA is too low, dichlor is ideal. But, if your CYA is high, and your pH is low . . . you'd better use another chlorine source.
    But all this requires actually knowing what your pool water levels are. 'Guess-strips' are not very accurate, and never reliable. Pool stores are slightly more accurate, but equally unreliable. We receive almost daily reports of bogus pool store test results.
    One of the facts the Pool Chart aggregate data is making clear is that, as hard as we push better test kits, we don't push them hard enough. The relationship between inadequate testing and persistent pool problems is very strong. You ask how you can know how much of each chemical to add, to get a specific ppm level. The more important question is, how do you know what you need to add?
    And the answer to that question, is to use a good test kit.
