Thread: Muratic Acid : 20 Baume'
    Sacramento, CA
    Question Muratic Acid : 20 Baume'
    My test kit (Leslie drop) gives a table for lowering pH with Muratic Acid - 20 Baume;
    what the heck is 20 Baume??
    thnx
    Mike K
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Muratic Acid : 20 Baume'
    It is another way of saying 31% by weight muriatic acid (The standard concentration you get at a pool store). Baume is a measure of specific gravity, or density, of a liquid. The higher the density over plain water, the more more concentrated the acid. As long as we are giving alternate names for things did you know that muriatic acid is commenly called hydrochloric acid (HCl) in scientific circles and muriatic acid is considered an archaic name?
    Sacramento, CA
    Waterbear,
    thanks for the answer.
    I knew that Muratic Acid is HCl - it's listed as the active ingredient.
    btw, I think I remember seeing some Muratic acid with a different percentage, like 36% , maybe. Not sure though.
    thnx
    MikeK
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    You cannot get more than 31% Baumé, so you will have to find out where you saw that and its standard.
    Pat.
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by PatL34
    Pat.
    Baume is not expressed in percents. 31% by weight is the same as 20 degrees Baume. What is labeled Muriatic acid is usually 31% by weight or 20 degrees Baume. If the acid is at a different concentration it is usually labeled hydrochloric acid, not muriatic. Anything over 25% by weight is considered to be a corrsosive chemical and 33% to 40% by weight is considered to be concentrated HCl. The percentage refers to the amount by weight of hydrogen cloride gas dissoved in water. Hydrgen chloride gas is the fume that chokes you when you open the bottle.
    Saint Cloud, FL
    Thanks for the correction, Evan. My memory banks ain't what they used to be.
    Pat
  1. Hello all and muratic acid question
    By BryanB in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-12-2011, 08:09 PM
  2. Muratic Acid to swim time?
    By JJParrish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-29-2007, 11:07 PM
  3. Help! Used Muratic acid instead of bleach!
    By SLR_65 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-19-2006, 10:52 PM
  4. Where to buy muratic acid?
    By s0undone in forum Dealing with Alkalinity and Calcium
    Last Post: 06-11-2006, 12:41 PM
  5. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
