Thread: Pool and Spa Lights
    Aug 2012
    Las Vegas, Nevada
    Default Pool and Spa Lights
    I recently purchase a home with a pool and the underwater lights didn't work. I removed both housings for inspection and found both to be filled with dirty moldy water. Is it usually possible to clean and salvage the housings and just purchase new bulbs and gaskets? or does it do permanent damage to the housing being exposed to water for long periods?
    Largo, Florida
    Default Re: Pool and Spa Lights
    Quote Originally Posted by shubb1282 View Post
    As long as the housing its-self wasn't damaged in such a way to cause it to leak again, you might be able to repair it with bulbs and a gasket. I bought a home with a light in a state similar to yours and i fought with repairs and leaks in the light for about a year before I broke down and bought a new light.
  1. Pool Lights
    By Shandyjo in forum Pool Equipment & Operations
    Last Post: 08-06-2012, 11:46 PM
  2. adding fiber optic lights to existing pool/spa lights
    By jjjjj in forum Pool Equipment & Operations
    Last Post: 07-07-2012, 12:30 AM
  3. Pool lights
    By JJNMRSDAD in forum Pool Equipment & Operations
    Last Post: 07-01-2011, 12:27 AM
  4. AG Pool Lights
    By Islander2C in forum Pool Equipment & Operations
    Last Post: 06-05-2007, 10:07 PM
  5. Pool Lights
    By Jinx32 in forum Pool Equipment & Operations
    Last Post: 09-09-2006, 10:46 PM
