Thanks for the ultra fast response. I found some at the local Marc's store. I think it is called A1 Austin's , or something like that.
28' round 18K gal AG pool; Pool frog chlorinator and mineral pac; Pleatco PWWCT150 cartridge filter; Waterway 1 1/2 HP, two speeds pump; 24/7 May - Sept hrs; HTH 6way.; 4' x 20' Fafco Solar panel ; utility water; PF:6.7
Have you guys seen the new bottles of 8.2%? Clorox and the local HEB store brand have switched to the 121 oz bottles and did completely away with the 182 oz bottles of the 6.25% strength - they also went up on the price![]()
16.5 x 36.5 grecian 25K gal IG vinyl pool; bleach; Hayward DE filter; 1 speed pump; 12 - 14 hrs;Taylor K-2006; utility water; summer: none; winter: none; iphone; PF:7
Pool Chart data processed to signature; note corrected pool volume based on the dimensions you supplied.
Thanks Ben! I think I put the wrong data in the pool sig table...my deep end is 8 feet, and when I plug this all in to the pool calculator it says it's 25900. Am I miscalculating somewhere?
PS: I used the smaller 121 oz. bottles of the 8.25% bleach and it works just as beautifully as the 6.25%!
I've got your entered dimensions as a 16 x 36 rectangle, with a 3' shallow end and an 8' deep end, giving a water depth of 2.5' and 7.5'. I do see that you show a 16' width; this may be an error. Typically 36' vinyl rectangles are 18' in width.
But, if your pool IS 16 x 36, 3' - 8', then the 17K gallon figure should be close.
