Are there any real advantages to higher turn over rates?
I have an Intex 637R rated at 1000GPH free flow. I understand that when the filter and corrugated tubing is figured in, this rate drops significantly, best quick guestimate would put it somewhere between 400 - 600 GPH. With my pool being somewhere between 4.2K and 4.5K gallons, this puts the turn over rate at about 8 hours.
What I'd like to know is if there is any real advantage to a higher turn over rate, as in 3 - 4 hour.
I think this could be achieved by reducing the restrictions in the plumbing, by going to a 1.5" PVC system, with only short sections of corrugated at the pool wall and pump. My gesstimate would be given the restrictions of the remaining corrugated, and turns (ells) in the plumbing should bring it somewhere between 600 - 800 GPH. Giving a turn over around 5 hours.
I will probably have to buy a better pump anyway, as I am planning to add solar heating next year as well. Knowing that the 637R would not be able to drive the additional restrictions of the solar, I would still need to put in a more robust plumbing system.
