Re: Calculating dosage for borax and dichlor powder for Intex easy set pool
Yes, that's the dose chart that I found...does that chart apply to bleach as well?
I will fill out the pool chart next.
Also, I've got a leak in my inflated ring and am trying to find it with soapy water...any advice is welcome! I'm going to double-check the seal at the valve, too.
Thanks!
