Thread: How Long Is The Typical Backwash Cycle?
    Richmond, IN
    Default How Long Is The Typical Backwash Cycle?
    Good Morning, Everyone.
    How long do you typically backwash when using a sand filter?
    Thanks,
    Paul
    duraleigh Guest
    Default Re: How Long Is The Typical Backwash Cycle?
    Hi, Paul,
    Ideally, you have a sight glass and can see the water turn reasonably clear as it goes thru. If not, look at the waste water wherever you can see it and, when it mostly clears, you're done.
    Mine takes somewhere around a minute more or less.
