Thread: Pressure Switch on Pool Heater
    Jul 2012
    Texas
    Default Pressure Switch on Pool Heater
    I have a Jandy pool set up and have not been in the house for a few years. I am back now and I tried to use the spa and heat it. When I turn it on, the Pressure Switch blinks red on and off. I remember I used to have a similar problem and would just turn the system off, then back on and it would work. Now, when I do it, the heater does a small click and then nothing.
    Any suggestions? Would a plumber fix this or is it a pool guy repair?
    Thank you.
    Default Re: Pressure Switch on Pool Heater
    The pressure switch on a pool or spa heater is a pool guy repair -- you might want to look up South Central Pool Supply aka http://www.scppool.com/ and call the nearest distributor. They probably won't make a recommendation, but can tell you who works on your brand of heater.
    Jul 2012
    Texas
    Thank you very much for the advice. Will follow up!
  1. Vacuum pressure switch for Barracuda?
    By henryb in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-11-2012, 09:25 PM
  2. Hayward H2001 pressure switch wiring question
    By bradm49 in forum Pool Equipment & Operations
    Last Post: 05-17-2012, 04:05 PM
  3. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  4. Pressure switch is leaking
    By milesmor in forum Pool Equipment & Operations
    Last Post: 10-04-2010, 12:14 AM
  5. Blocked Pressure Switch
    By kevreh in forum Pool Equipment & Operations
    Last Post: 05-15-2007, 09:22 PM
