Results 1 to 10 of 55
Thread: Fighting Algae for months
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default Re: Fighting Algae for months
    The only advice I can share with you is this forum will absolutely fix your problem, BUT ONLY if you follow their advice to the letter! If you deviate, you will increase the time you spend correcting your pool water chemistry.
    I was a new user of this forum earlier this spring. After following the advice given here, my pool is crystal clear and has been all summer. Oh yea.....and get the good test kit right away....the Taylor 2006c kit. You will need it.
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    rkrgk is offline Subscriber Thread Analyst rkrgk 0
    May 2012
    Phoenix, AZ
    Thanks Sabres07! I was reading some of the information posted at this forum and it is really informative and 'eye-opening'. And like you said, I will follow what will be suggested, I can see that a lot of people benefit with this forum. And yes, planning to get the Taylor 2006C, too bad can not buy in a local store, so will wait for amazon to ship. I just wanted to start on it faster, so got the HTH kit for now.
    Watermom,
    I got the HTH test kit and here are the results. I posted the Pool chart Entry form as well.
    Test Results
    Chlorine - <0.5ppm
    Alkalinity - 50ppm
    pH - >8.2
    Hardness - 400ppm
    CYA - <30ppm
    18x32 kidney 15K gal IG Gunite pool; skimmer tabs; Hayward DE6000 DE filter; Hayward/AO Smith Superflow 1 speed pump; 12 hrs; heat pump, fountain or waterfall; Taylor K2006C ; utility water; summer: none; winter: none; android tablet; PF:8
    May 2012
    Phoenix, AZ
    With the test strips, I get pH to be 7.2, that's the reason I had not adjusted so far. I know we can't rely on the test strips but seems quite a big difference.
    So, can I go ahead and put bleach or should I lower the pH first?
    Looks like pool is getting worse and worse. I got 1 gallon of muriatic acid and six 1.5 gallons of 6% bleach from Walmart. And BTW' the tabs that I use are 94.5% trichlor. Should I get some stabilizer and add before I add bleach?
    Thanks again for your time.
    Go ahead and add 2 of those big jugs of bleach. Each of those should add about 5.7ppm of chlorine. Since your CYA is below 30, let's have you use around 12pm as your shock level. Test your chlorine as many times per day as you can, and each time, add enough bleach to take your chlorine back up to around 12. You want to continue to keep the chlorine at shock level until you can go from sundown one evening to within two hours of sunrise the next day without losing more than 1ppm of chlorine, you have a CC reading no greater than 0.5 (your K2006 kit will be able to measure this) and the water is clear. Then, keep it high for one additional day. For reference, each quart of 6% bleach will add 1ppm of chlorine in this size pool.
    Until you get the good kit and are having to use the HTH kit, your limited to measuring chlorine levels to 5. But, you can force your kit to read higher by using a dilution method explained here: Testing Without a Good Kit
    Go ahead and use some muriatic acid to lower your pH. Please read the link in my signature about using it safely. Please note that your pH test results will be inaccurate when your chlorine levels are high so do pH testing when the chlorine is below 5.
    Run your pump 24/7 while you are trying to clear this and clean the filter as needed. Live algae clogs DE filters fast!
    I would not worry about adding any stabilizer until you get the pool cleared up. By the way, look at the ingredient label on the trichlor. Any mention of copper?
    Hope this helps.
    May 2012
    Phoenix, AZ
    I usually pour bleach walking around the pool, hope thats the right way to do it? Or putting it slowly through the skimmer is better?
    The trichlor that I mentioned (tabs from costco) does not mention any copper in the label.
    My pool looks like this now.
    Most people either pour it in front of a return jet or slowly into the skimmer. I use the skimmer. Another advantage of putting it in the skimmer is that it will kill anything growing in the filter, too.
    Actually, since this is not a vinyl pool, you don't have to be so careful of not taking the chlorine too high. So, you can hammer it with bleach.
    May 2012
    Phoenix, AZ
    Ok, so I added 3 x 1.42 Gallons of 6% bleach and did a chlorine test after 1 hr. The results show somewhere in between 3 and 5ppm. I did the dilution method that you mentioned and got the results to be 5ppm. So I would think its about 4.5ppm currently. Its 104 Degrees hot here in Phoenix, so may be all the chlorine that I put might be evaporating faster than I can pour!
    I brushed the pool a bit. Didnt backwash the filter yet, Did backwash and added DE just two days ago.
    The pool has bit of powdery particles floating on top, Dont know if its due to me brushing the pool and some DE is floating or if its the bleach reacting with Algae. And the fact that my pop up cleaning system is not really popping up and cleaning makes me worry.. Should I be buying a vacuum cleaner? Other than that how will I remove the debris? And how can I make sure my drain is working? I can not see much of water movement at the deep end of the pool. Could it be that my drain is somehow clogged?
    Here is the picture of partcles floating on the top
