Thread: Pool Pump that will not kill itself
    Largo, Florida
    Default Re: Pool Pump that will not kill itself
    I live in FL and have similar concerns when on vacation. What I do is have the pump suction set only to the main drain (no skimmer) when I go out. Alternatively, you could get an autofill device like this one: Rola-Chem-M-3000-Rola-chem-Pool-Sentry Of course you run the risk of flooding the backyard if the thing were to fail and get stuck "on".
    I can't find any low water shutoff switches specially designed for pools, maybe someone else has seen one.
    mas985's Avatar
    Pleasanton, CA
    Normally, a skimmer is usually plumbed with bypass either to a wall port or main drain like this:
    https://poolplaza.cybrhost.com/pool-...ercutoff.shtml
    This is suppose to prevent the pump from running dry although it doesn't always work as planned.
    Mark
