Thread: Ultra -Flow Pump
    Aug 2012
    Default Ultra -Flow Pump
    Hi,
    I am in the process of changing the impeller on the ultra flow, after figuring out how to remove the old impeller I noticed the new one did not cover the front of the motor shaft and there is a threaded insert on the shaft for a bolt/screw to keep the impeller from coming loose. My question is Does anyone know what the bolt/screw size is, and is it a reverse thread? The impeller screws onto the shaft normally.
    Thanks in advance for any input!
    Wayne
    Default Re: Ultra -Flow Pump
    Membership upgraded; thread moved so you can post.
    PICTURES! Take pictures of your pump - even in pieces -- and we can probably tell. Post the pics with Picasa, Flickr, Webshots or Photobucket. You can also email them to me at [email protected], and I'll post them -- but it want be before Thursday.
    Aug 2012
    Thanks PoolDoc,
    The old impeller didn't have a screw but was solid and it covered the screw hole. So I just installed the new impeller the same way, the rotation keeps the impeller tight so there wouln't be a need for that screw. Thanks again.
    Wayne
    If it works . . . it works!
    Ben
  1. 2HP Ultra Flow Pump Titan SS DE Filter
    By fasttruck9 in forum Pool Equipment & Operations
    Last Post: 08-24-2012, 11:47 PM
  2. No flow to booster pump
    By mjcogan in forum Pool Cleaning: Manual or Automatic
    Last Post: 03-21-2012, 10:27 PM
  3. Low flow on pump...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-19-2006, 09:18 AM
  4. No water flow at pump
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 02:24 PM
  5. No water flow at pump
    By vinouspleasure in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-11-2006, 08:11 PM
