Results 1 to 10 of 10
Thread: Suggestions on how to clean Pool before packing it up?
    Jun 2012
    Michigan
    Question Suggestions on how to clean Pool before packing it up?
    I'm not exactly sure when I'm going to take down my pool, it depends on if the weather holds out or not. With these cooler nights and daytime temps only hitting 80 the water has been pretty cold. So I guess when the mood strikes me is when its coming down.
    I've had some algae and am currently in +SHOCK+ mode so I figure I need to clean pool thoroughly before taking down and packing up. Mind you the algae was never out of control, the pool never turned green etc. Nice clear sparkling water, I just would have a break out every so often and I'd be on top of it immediately.
    There was a thread in the last few days that Ben had advised someone:
    " Just drain 3/4 of the pool, add ALL the algaecide, slosh it around with a brush, and leave it overnight. Slosh again the next day and finish draining. That should take care of your algae, and give you a clean pool to refill."
    Granted these instructions are not for take down but for refilling.
    I had been wondering How I was going to clean the pool walls etc before packing it up. I have absolutely no slimy feeling to my walls or floor but still feel it necessary to do something before folding it up. Of course I plan on vacuuming the pool and keeping the chlorine level up before draining. Maybe it's my OCD in play IDK, am I over thinking this? lol
    I plan on packing the liner in a tightly sealed plastic tote with plastic btwn the tote and the lid to keep out the bugs and any other tiny critters that may try and find their way in. Seeing how I may also have a stray cat living in my garage for the winter, duct tape has even crossed my mind to assure he doesn't get it open.
    So to make my long story short--Anyone out there that's ever done this before have any tips and tricks for a first time Intex owner that will make take down easier and not negatively effect next years start up? I do have a bottle of AquaChem algaecide that I could use but don't know if the residue from the chemical will remain and hurt the liner while being stored. Thanks and sorry for the long post, I am sleep deprived this morning and just couldn't find the right words to shorten this post up!
    15' x 48" round 4.4K gal Intex AG pool; Unicel Type C-5315 cartridge filter; Intex 633T pump; (24/7) Taylor 2006 kit; utility water; summer: ; winter: ; iPhone; PF:27
    Default Re: Suggestions on how to clean Pool before packing it up?
    bumping this post up to see if anybody has suggestions...
    Jul 2012
    Mexico, Missouri
    No suggestions, but I do thank you for your post, as I am also in that situation.
    What I am probably going to do, barring more experienced suggestions is drain until 4 - 6 inches remain then add 1/2 gal bleach + 1/2 gal algaecide then thoroughly scrub the entire pool, inside and out. The instructions that came with the liner say that it needs to be well dried before folding for storage, so that is also in the plan.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jul 2012
    Kansas
    We typically drain all but a few inches, add a little dish soap, toss in the kids and have them scrub all surfaces, drain and rinse a few times. Then let dry for a day or two in the sun before packing away.
    Based on my, and my friends' past experience, you need to make sure the pool is 100% dry before packing it up. The slightest bit of moisture and you could have mold/mildew growing on it inside that tub and may open it up in the spring to find the mildew has eaten through some of the vinyl (My friend's Intex the mildew had completely eaten through the air ring, all the way around the pool!) We have had mice or crickets eat small holes through the vinyl liner and pool inflatables that were in boxes or plastic tubs in our storage shed and garage in the past. (Many of the plastic tubs will still have "air holes" under the handles and I'm guessing that is how those crickets got into the tubs)
    16' round 5K gal Intex AG vinyl pool; 8.25% bleach; Unicel & Filbur cartridges; Intex Krystal 635T pump; 8hrs; Taylor K2006; utility & well water; summer: none; winter: take down; android phone; PF:24
    Jul 2012
    Mexico, Missouri
    Quote Originally Posted by 7sanders
    So duct tape around the lid it is.
    Your dish soap routine -- is that with or without mustard algae remnants? That is why I would be using the bleach, as most algae can survive being dehydrated for years, and as soon as conditions permit, come back in a full bloom. I'd rather avoid that.
    Jul 2012
    Kansas
    without mustard algae as far as I know. One year it was some REALLY green/slimy water in a smaller pool -1500 gal (when it's 117 outside, the pool wouldn't get under 105, and wouldn't keep chlorine no matter how many bottles I added!) and the next year it was fine and had no algae blooms (but again, probably not mustard algae)
