Re: DIY solar heater question
If you bypass most of the water around the hose, then the water coming out of the hose will likely be high due to the lower flow rates but that just means you are losing a lot of heat to the environment. The idea is to have high flow rates through the panel and have very little heat rise. This is what maximizes heat transfer and efficiency.
