Results 1 to 10 of 32
Thread: Filter not doing the job?
    Jul 2012
    Chicago
    Default Re: Filter not doing the job?
    Thanks for the advice. I'll look into skimmer socks. Regarding vacuuming to waste... it takes me a couple of hours to vacuum my pool. That is a LOT of water to be dumping, isn't it? Seems to me I'd have to be filling at the same time and probably wouldn't be able to keep up.
    18x36 rectangle 20.6K* gal IG painted concrete pool; floater; Pentair Tagelus sand filter; Pentair SuperFlo 1.65HP pump; 12 hrs; gas heater; K2006 Taylor; utility water; summer: none; winter: Haven't gotten to my first winter yet; none; PF:5.8
    Jul 2012
    Cincinnati, OH
    Thats true .....I brush the walls, let the water sit for a few hours so all the sediment settles to the bottom of the pool(pump off) then while filling I quickly vacuum what I can(usually about 10-15 minutes),,,just hitting the heavy areas. Of course this was a last resort only when water was extremly dirty.
    I wouldn't do this untill the algae was dead(blue color).
    Water is cheep and plentifull here in Ohio....not sure what its like in your area.
    As I said before since I started getting advice from this site on how to properly treat my water I have not had any problems.
    Thanks everyone!!!
    papa
    18x40 Lazy L 30K gal IG Vinyl pool; tri-clor feeder; Hayward #250 sand sand filter; Hayward super-1-1/2 HP pump; ; Taylor 2006c; utility water- PF:4
    Quote Originally Posted by gogolion View Post
    Why does it take so long? We vacuum a 45' x 75' pool in about 45 minutes. Granted, we use a 36" vac head. Do you need a better vacuum system? If you have good suction at the skimmer, this vac head is probably what you want:
    Pentair R201286 222 Pro Vac Series Commercial Pool Vacuums
    We use the larger model of that head, but you need REALLY good suction if you do. If you are careful, you can vacuum very quickly with that head. Unless your pool is rough, we could vacuum it in about 30 minutes.
    Jul 2012
    Chicago
    Hmmm, maybe I'm not getting good suction.
    Is there a way to measure that? It feels pretty strong to me on my hand, but then again I have nothing to compare it to. I think I have a 24" vacuum head and I definitely do not get suction the entire length of the head. I really only cover a few inches wide with each pass of the vacuum. I plug one of my skimmers when I vacuum to get better suction. I guess I'll also try turning off my main drain. One thing I've never understood, which could be a cause of poor suction, is that air always seems to get air in my system when I vacuum. Air is always gurgling out of the returns. I have no idea where it comes from since no air gets in when I am filtering normally. I always make sure my pool is full (middle of skimmers) before I vacuum.
    Sounds like a suction leak. If it is, it will probably get worse when you close the main drain. And, a suction leak will definitely impair vacuuming.
    However, using a 1 1/4" hose, instead of a 1 1/2" will mess vacuuming up, as well. Also, stiff vacuum heads sit too high above the surface, and not create the high flow / high suction necessary for good vacuuming. The ProVac heads conform to the pool surface much better than any others I've used.
    Jul 2012
    Chicago
    I went to the pool store today to get a skimmer sock. They guy there said the skimmer sock won't catch fine particles such as algae. Instead he sold me some cullulose fiber DE replacement that you put into your skimmer to help your filter grab the fine particles. He said to add it 1 scoop at a time to my skimmer until the pressure goes up 1psi. I told him that my pressure never seems to increase and he said I may need more or new sand. So I went home and after adding 5 scoops my pressure didn't budge. I called the guy and he said add 2 more scoops and if it still doesn't move then I probably have a problem with not enough sand or needing new sand.
    Can the kind folks here please give their opinion on the pool guys' diagnosis? If I do need to add sand or new sand is there a guide on this site somewhere of how to do that?
    Thanks in advance
    Did someone here suggest a skimmer sock for you? They definitely won't remove algae.
    Cellulose fiber may gum up your sand, but you can remove it when you work on the filter. Doing so is a pain on top mount filter -- you have to cut the plumbing, before you can unscrew the valve!
    There's a good chance your pump is too big for your filter, and has been blowing sand out every time your backwash. You'd have to give us actual pump and filter model numbers to be sure.
    Jul 2012
    Chicago
    Yes, earlier in this thread someone suggested skimmer socks. Luckily the guy at the store steared me away from that.
    Here are my model numbers:
    Pump: Pentair model SF-N1-1-1/2A/340039
    Filter: Pentair Tagelus, Part #145241
    Please let me know if they are mismatched.
    This equipment was all installed this year by a pool company. I'm probably under warranty if it is malfunctioning or was installed incorrectly.
