RE: heaving
Nice to hear from old friends from the forum again, and to see it buzzing and coming out of hibernation from the winter!
We actually poured cement footings with a bracket cemented in the top that we attached the (I believe) 4x4's to. By not setting the posts into the ground we hope to avoid the posts rotting out. If they should need replaced in the future it can be done easier too. I learned entirely too much about deck construction, and plumbing last summer, lol, just glad it's done!
I didn't notice any change at all in our deck this winter. It weathered very well with no heaving that I could tell. If you go with composite- it is recommended to use a plastic snow shovel, that is if you live in the cold country.
Also- I chose to go 12inches on center instead of the recommended 16inches by Timber Tech. The guys cussed me the whole time we built it, but it's as solid as a rock!
I highly recommend composite decking by a pool. The Timber tech does get a little hot in the sun- but the finish is nice to walk on. I used the twin finish boards with the vertigrain side up for extra traction with wet feet. They do have some that lock together - but the seep holes get clogged very easily with dirt/debris. We used those special screws that mushroom up a little- then you pound it down in and it covers the screw head. Makes a really nice finish. Like I said - use the 16pinny nail for gaps, though. We have a big deck - and I'm anal about keeping it clean - would have made my job much easier.
We left about an inch gap and notched around the uprights by the pool. It was plenty to put the winter cover down through. The worse part was getting on your knees to do it! It is enough gap that diving sticks... can fall down through- but I found a cool basket from Shopko that I keep all my fun toys, goggles... in and it helps solve that problem. We enjoy our pool 100 percent more with the deck and nice walk in steps.
Sincerely,
Donya (huskerfan)
