Yes! Dermatologists prescribe "bleach baths" for even pediatric patients at levels 10x higher than that (and effectively, more like 100x higher, because the bleach bath water has no stabilizer)!
LOL, a common practice for us Southerners who live in the country is warm baths with a cup of bleach following any excursion into wooded or high grass/weed areas in order to kill off chiggers and release seed ticks. I don't know if you can even measure chlorine levels that high, but I promise that it exceeds 10 ppm!!![]()
. So, from today on, i am to let my chlorine drop to 10 ppm, adjust ph back to 7.6, and continue sweeping and brushing till the cloudiness clears up?
16 round 5.3K* gal AG vinyl pool; Skimmer tabs; Intex cartridge filter; Intex model 635 1 speed pump; 24 hrs; ; Hth 6 way; delivered via truck; summer: none; winter: vinyl / water bags; iPhone; PF:23
PoolDoc / Ben
Okay, still blue and cloudy here. Chlorine is 10+, but more yellow than orange... Which i plan on maintaing, however ph has dropped now to 7.2, i'd ideally like it to be a little higher for flex room... How much borax should i add, and do i add it to the skimmer, or directly in pool?
How is your pool doing, now?
Pool is looking great! Chlorine at 5-10, ph is 7.5, i can see the bottom of my pool again! It is blue, but still a little cloudy. So happy with the results! Thanks for all your help!
glad to hear it. -ben
