Results 1 to 9 of 9
Thread: Just started with PoolForum
    Aug 2012
    Seattle, WA
    Default Re: Just started with PoolForum
    Thanks - found a taylor K2006C on Amazon and ordered it - I think I have enough chems to finish the season with Baqua, and then let the baquacil run to 0 and start over next season. I suspect my water supply has loads of chlorine - it occasionally smells pretty strong!
    16x32 oval 17.5K* gal AG vinyl pool; Baquacil; DOUGHBOY sand filter; DOUGHBOY 1 speed pump; 12 hrs; solar heat; BAQUACIL STRIPS; utility water; summer: solar; winter: none; none; PF:6.9
    Keep in mind you do NOT need to test chlorine or CYA levels till you convert. There are only about 9 CYA tests in the K2006-A, so you don't want to waste them.
    Aug 2012
    Seattle, WA
    Thanks - buying the kit in advance so I don't have to panic later....
    Quote Originally Posted by chickgreen View Post
    You are so smart! Welcome to the Pool Forum, by the way!
  1. PoolForum abbreviations 2011 => DE, TA, CYA, etc.
    By airraid1999 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2011, 10:55 AM
  2. On TFP and PoolForum
    By ChuckD in forum General Interest
    Last Post: 04-21-2008, 11:30 AM
