Thread: ps234 test results - first post
    mbar's Avatar
    Ashland, PA
    Default Re: ps234 test results - first post
    If you want to bring up the ph, use Borax, it won't raise the alk. much, if at all. But since you have low alkalinity - you want it between 80 - 120, you can add baking soda - it will raise both ph and alk.
    Here is a link for the bleach calculator, click on the top more calcs) and there are other calculations, there is one for ph and alk
    http://www.hal-pc.org/~mwsmith2/BleachCalc262.exe
    Northeast PA
    new jersey
    Thanks my ph went up to 7.5 so that looks good --
    If I want to increase the calcium a little what do I add --- I really don't want to get the powder chlorine with the calcium but if that is all I can do that I can use some pucks.
