Results 1 to 9 of 9
Thread: TA reduction going wrong ??
    Default Re: TA reduction going wrong ??
    I think you may have missed what Ben stated in his post above. Cal-hypo does NOT add CYA.
    Aug 2010
    North of Waco, Texas
    Watermom, thanks for ringing in on my post!
    I had to go back and take a 2nd look @ the containers my chlorine tabs came in. When I first purchased the home 2 years ago I inherited my Doughboy pool. My pool had originally been on bromine for sanitation. I drained and refilled my pool and started using Trichlor-triazineirione tabs after that. Some where along the way I had purchased 15 pounds on Cal-Hypo. I had quit using all the tabs when my CYA reached 50ppm and switched to the BBB method.
    I installed a cover for the first time last November and I pulled my cover off in the middle of July, add when I tested the water I found the CYA was gone. I ran the CYA test 3 time and same results, O ppm CYA. I thought I would use the tabs I had left over from two years ago to reintroduce CYA into my water. I have used about 6 pounds of Tri-Chlor I had left and the started using the Cal-hypo. Sorry for the confusion. I assumed wrongly both types of tabs contained CYA.
    Anyway when I used up the Tri-Chlor I had about 4 days ago and my test @ that time showed 30ppm CYA. I started aerating last evening and checked my PH and TA again @ 2:00pm central time. My latest test show PH 7.6 and TA 100ppm . At this point do I need to add CYA powder/granules to 80ppm before I start my SWCG for the first time?
    I do still have brown scaling on the bottom of my liner where it makes the transition to the wall. This showed up after last winter with a cover on or the first time? I have read on the Forum about possibly some metal getting into the water? Any ideas about that? Thanks again !!!
    16X32 vinyl AG Doughboy 12,600 gal w/ deck down one side. 19" Doughboy filter, 1.5 hp Hayward pump, CircuPool RJ20 SWCG, 440 pounds salt, maintaining 30 ppm borates; CYA 60ppm.
    I'm a little confused.
    Could you list -- just a single list -- of your most recent COMPLETE chemical tests: FC, pH, TA, CH & CYA?
    By the way, I took your test values OUT of your signature; those values will change, and leaving them in your signature could mislead someone into giving you wrong advice. And, as it is, I wasn't clear on what the date of those values was.
    Aug 2010
    Here are my test results as of 7:00pm central time today.
    FC: 2.0 ppm
    CC: 0 ppm
    pH: 7.8
    TA: 100 ppm
    CH: 90 ppm
    CYA: 50 ppm
    Borates: 30 ppm
    Temp - water: 80F, air: 95F
    Pool had just been covered with shade for the day!
    OK, thanks.
    Now, what are your current questions? I'm guessing they are:
    1. How do I remove the scale?
    2. Do I need to do anything else?
    I'll answer those two, in any case:
    1. Lowering your pH to 7.0 and keeping it there will cause your TA to drop, slowly. Low pH and low TA will maximize your chance of removing the stain / scale.
    2. I would recommend testing the stain / scale to see what will remove it. You can do so by holding various chemicals against the stain / scale for a couple of minutes. I'd recommend testing in this order:
    1. Vitamin C tablets
    2. Dichlor or cal hypo granular chlorine.
    3. Iron Out powder
    4. Sodium bisulfate (pH Down aka dry acid)
    You should wear plastic gloves, and put the chemicals in #2 - #4 in a old (but clean) wash rag.
    Let me toss in MY two cents:
    As much as we love the Taylor K2006 test kit (which, using your K2005 with the K1515 is the same thing) their advice about lowering T/A is nonsense and can damage your pool. Please don't use the "Slug" method, because IF it works, it's only by accident, not because the "theory" (ie myth) behind it is any good.
    As Ben pointed out, lowering your pH will lower your TA, but raising your pH after will raise TA back up again. The way around this is to lower pH as Ben said to about 7.0 and test your T/A.
    If it's now good, when you want to raise pH again (after you have followed Ben's instructions for treating the stains) you'll raise it by aeration, not by adding any chemicals. That's by using a sprayer, splashing kids, pointing the return at the surface so it bubbles, etc, which will raise pH. Since your TA is now 90 you should be at a pretty good level. If it was STILL too high, you'd repeat by lowering pH to 7.0 again. So the "Slug" lowers the pH and with it the TA and whatever aeration you get raises the pH safely back up. But the "slug" is not what works--the lowering of pH does.
