Hi,
I am in the process of changing the impeller on the ultra flow, after figuring out how to remove the old impeller I noticed the new one did not cover the front of the motor shaft and there is a threaded insert on the shaft for a bolt/screw to keep the impeller from coming loose. My question is Does anyone know what the bolt/screw size is, and is it a reverse thread? The impeller screws onto the shaft normally.
Thanks in advance for any input!
Wayne
