Results 1 to 10 of 43
Thread: Brown stains spreading
Threaded View
  1. #9
    Dec 2005
    Honolulu, Hawaii.
    Default Re: Brown stains spreading
    Cyanuric Acid Correction To Total Alkalinity.
    The following is taken from Taylor's "Pool and Spa Water Chemistry" (rev 9/94).
    "Total alkalinity is a measurement of both carbonate alkalinity and cyanurate alkalinity present in a sample. Since water balance calculations only use the carbonate alkalinity portion, a a correction (which varies with pH) should be applied to compensate for the cyanurate portion."
    They further state: "Note: While Taylor Technologies recommends using the correction, some industry professionals remain skeptical and question its value."
    It works for me I seem to have far less variation on a daily/weekly basis if I use the adjustment.
