Re: Brown stains spreading
Here is the ascorbic treatment:
You will need about a half to one pound of ascorbic acid per 10,000 gal. I like to go lighter on it and see if all the
Put the filter on circulate.
Use a cup and go around the perimeter of the pool and drop it down the sides as you go.
Let the ascorbic acid circulate for 1/2 hour. You will be amazed how the stain just disappears before your eyes.
If the stain is not all gone, leave the filter in circulate and add more ascorbic acid close to where you still see stain. Leave it in circulate until all of the stain is gone. (add more ascorbic acid if it circulates for 1/2 hour and there is still stain)
When the stain is gone, add enough sequestering agent for the volume of your pool - more is better than not enough.
Put the filter back on filter and leave it on 24/7.
The ascorbic acid will bring your ph down, after 24 hours you can start to bring up your ph and alkalinity - use baking soda first, it will raise both ph and alk. Make sure you test in between, because you don't wantyour ph to go any higher than 7.2. If your alkalinity is in range, and you still need to raise your ph, use Borax to take it up to no higher than 7.2. After 48 hours you can start to bring up your chlorine. You want to do this slowly. It will take a lot of chlorine - I prefer to use bleach only at this time, and try to take it up to your minimum chlorine for your cya according to the "best guess chart" Do not shock! Do not shock for at least 2 weeks! Make sure you keep your ph low for (7.2) for a week or two - it won't be hard because the ascorbic acid will help it stay low. Once your chlorine starts to hold, it means that you have used up the ascorbic acid in the water and it will be easy to rebalance the pool back to your regular parameters.
Since your pool is 8500 gals, I would add 2 cups of bleach at a time. You can start to do this after 2 days. If you are in a hot climate, you may want to add some polyquat before the treatment to keep algae at bay. You will have to test often, because the bleach will get used up breaking down the ascorbic acid. Once you start to raise the chlorine level, keep it consistant - don't let it yo yo down. Take your chlorine up to the lower level of your cya "best guess chart". Let me know if you have any other questions - good luck!
Northeast PA
