Results 1 to 10 of 12
Thread: Fire department water??
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    Default Re: Fire department water??
    I had the fire department fill my pool after I had it 1/4 of the way full out of the garden hose (to let the liner get settled). I live in the city limits and have a hydrant in the corner of my property so it was filled with city water completely. I made a $50 donation to them and they were happy to do it for me (volunteer fire department). They say they pay a set rate for water whether they use 10 gallons or 100,000 gallons, so they don't mind doing swimming pools around here. I know your situation is a little different, but if you follow the advice of this web site and poolsoutions.com you will have your water in perfect shape in no time. If you are going to completely fill out of a fire truck I would have them fill the first 1/4 of it slowly so the liner will settle properly and then fill it up faster after that. After I got mine to that point it only took 45 minutes out of the hydrant and I was swimming right after. I would definately check into the fire department option for sure!!
    Good Luck!!
    Benton, La
    I am on the FD here in our town & we refuse to do it because of problems that could arise from our water. I have NEVER seen clean water come from our trucks regardless of where we pull it from.
    To me, the $800 for good CLEAN water would be much better than the headaches you will face trying to clear up nasty water from a fire truck, especially if it will be pulled from a pond.
    27ft. Round AG Pool
    Gordonsville, Tn.
    They actually didn't use a truck on my fill. It came straight from the hydrant and 150 ft of fire hose.
    We don't have that option either way and have to use well water. Trucking company will not haul this far out and Fire Dept won't due to liability issues and we are too far from town.
    Properly filtered before going in, what is the problem with well water except that it is slower? Tested prior to use for metals and contaminants, if safe to drink and use in the house, then it should be safe for the pool, shouldn't it? We have some metal content but are using triple filtering prior to reaching the pool and the metal out at fill just in case some gets through. The only issue so far is it takes SO long.
    Joliet
    Our city fire dept. uses city water...which is the same water that you drink, bathe and cook with. Our city doesn't fill pools...but I would be very confident in the quality if we did fill them (as it's the same city water).
    However...I,personally, wouldn't wouldn't accept pond water from any source (fire dept or otherwise) unless I was swimming in a pond. $800 is alotta money...but I think I'd have to pay it. Let's see what those "in the know" say.
    good luck,
    dan
    jabbajean Guest
    Wow..you guys are quick. Thanks for all the opinions. Our well water is wonderful, but our well isn't that deep so we would run out of ater in the house..three kids so we can't afford to be with out water. We had a 10 ft intes and it drained our well. Our friends filled their pool, an inground ,with the pond water and now it is sparkling.
    So, lots of food for thought.
    Thanks,
    JAy
    I have seen about five pools filled from a fire hydrant. The water, in all cases, had a brown rusty look to it. It would be several days before I would want to swim in it.
    The last pool I set up for myself was a 15 x 30. We had a well at the time. I just took my time and filled it a few inches, a couple of times a day. It took a week or two but we never ran out of water.
    The kids had a blast playing in it every day. The never cared how full it was. I even ran hoses from my filter over the pool wall and into the water to keep it clean. I also had two daughter in college at the time so my money had better uses than a water truck.
    Best of luck with your pool, Dennis
