Re: Replacing a liner in a 16x32' inground pool
Thanks,
I am planning on adding the 2" foam to the existing hopper bottom
Then add some 8x16 pavers to hold them in place, add sand/small rock to level off.....then compact as much as possible
Then pour a new floor on top of the sand etc..........I'm thinking of only raising the floor less then 12"
2" rigid, 2" sand etc....Then 4" concrete on top of that - would that be enough ?
I'm not sure fo the difference between concrete and cement......just the mix ?
If the vermiculite/sand/cement mix is better then I can go with that, HD has 2 cu ft vermiculite bags for $21
Smoother is better for the liner
-Dave
Reason: turn signature on
16x32 rectangle 16.6K* gal IG vinyl pool; Chlorine; Hayward Pro-Grid DE4820 Vertical Grid DE filter; Hayward 1.5hp SP3010X AZ15 1 speed pump; 4/8/2012 hrs; solar heat; drops method; Rainwater; summer: solar; winter: mesh; none; PF:7.2
