Thread: Sand Filter
    Aug 2012
    Florida
    Default Sand Filter
    I have a 25,000 gal pool with a 1 hp pump and 1 1/2" piping. The current sand filter needs to be replaced it's a old Hayward S200 series. Would a Hayward S244tT/T2 be to big? Thanks
    18x36 rectangle 25000 gal IG vinyl pool; tablets; Hayward sand filter; 1HP 1 speed pump; 12 hrs; ; pinch a penny dual test kit; utility water; summer: none; winter: none; iPhone; PF:6.2
    Default Re: Sand Filter
    No, an S244T would be fine.
    If you pipe the connections with unions, the filter will be MUCH easier to service, when that's needed.
    I've upgraded your membership to Registered access.
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    By MikeInMo in forum Pool Equipment & Operations
    Last Post: 05-31-2007, 12:01 AM
  4. Sand in bottom of pool from sand filter
    By nicole12 in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
