Re: New to AGP's
Congratulations!
How long to fill depends on the flow from your tap. You should have about 12,000 gallons so if it's 1000 gallons a minute, 12 minutes!
100 gallons/minute, 2 hours. 20 gallons a minute, 10 hours, etc.
I like to add bleach as soon as I have a foot of water, dribbling it slowly all around the pool, but NOT on the liner! A single gallon of bleach will be fine for the first fill and gives you some protection. You MAY want to prepare a dose of CYA in an old stocking also. Figure to use no more than HALF of what they recommend for your 12,000 gallons. Even a 1/4 is fine--it's easy to add more, hard to get rid of. Testing will wait till the pool is full.
One thing to check. Make ABSOLUTELY certain the maximum flow the filter can tolerate is greater than the maximum flow of the pump. If it's not, either get a bigger filter or a smaller pump.
Re: New to AGP's
i bought CYA in liquid form so what to do?
Re: New to AGP's
Liquid form? Does it say "Cyanuric Acid"? Not familiar with it.
Re: New to AGP's
Well let me clarify. I was asked which form I wanted and I was told liquid was easier cause it didnt have to be disolved. I havent actually looked at it so it may very well be powder form.
Re: New to AGP's
FYI, do a google search and you will find 100% Liquid CYA around $24 per gallon.
Re: New to AGP's
Well, the pool is up!!!!! I can't wait til you all come by for a glass of iced tea and a smoke to help break it in....J/k. I had some problems with the shipping and getting the parts here for the build as if you couldn't tell by the long delay in posting...
Got a question....I am filling with tap water... We live in the country so brown water isn't new. Will the water clear when it is pumped through the sand filter? I know we had a cartridge filter on a smaller pool and it did after a couple of days. Right now the pool is about a foot deep and yellowish brown.
I am also looking at what to do for the landscaping around the pool. Any ideas would be great....Thanks for your encouragement!
Re: New to AGP's
It should clear up. You can also add a little DE to the sand filter--1/3 to 1 cup, enough to raise pressure 1 lb. This will allow the sand to filter much finer particles. DE is pretty cheap--10# costs around $8 and will last a sand filter owner all summer. You need more DE everytime you backwash. You don't HAVE to add DE, though.
