Without some test results on your water (taken with drop-based testing, not strips!), we can't be of much help, since it is crucial to know your CYA levels in order to determine your correct chlorine level, and the other levels may or may not have anything to do with why your water was cloudy. Also, we need to know if there are any metals in your fill water, and need to know for sure that this was a chlorine pool and not a Bacquacil pool. What was the ingredient in the shock from Walmart that you used?
If you'll answer those questions, and fill out this short form with info about your pool, it will help us give you better advice...
Pool Chart Entry Form
